sessasells
Thread starter- Joined
- Jun 30, 2013
- 14
other than the obvious broken water pump belt. Engine is pumping 20-27 psi water pressure, but heats up to 190 in about 20 minutes at 2500 rpm, then alarm fires off and I shut down the engine for 15-20 min to bring temp to 180 until it runs hot again. Can thermostat not be opening all the way? Other suggestions?
