5.0glpwtr, block drain plugs
Augoose
the heads on my block drain plugs are starting to get rounded and so I want to replace them before it becomes a problem. Is this the correct replacement part, #78?
Thanks!
Don S
Re: 5.0glpwtr, block drain plugs
Yes, that is the correct part, but instead of ordering it from Volvo, go to your local plumbing store, hardware store, big box, or auto parts store and get a brass 1/4" NPT Hex plug. You could use a regular square headed pipe plug, but with the hex plug you have a head to use a wrench or socket on.
Augoose
Thanks Don- I had tried Lowes already but I couldn't match up the thread pitch but I was also looking in the metric bins- I guess that was the issue. I'll try your suggestion!
thanks again!
Augoose
Found 'em in the plumbing section-thanks!
