asmith147th
- Jul 4, 2012
- 5
I?ve got a problem with my 1999 Volvo Penta 5.0Gi PWTR that is in my 22ft Sea Sport. My mechanic hasn?t been able to fix, so thought I?d ask the forum for any ideas. I?m convinced this is a fuel supply issue, but I guess it could be electrical. It began with not being able to start ? I?d run it in the driveway before a trip. It would start easily and run smooth in the drive, but when I got on the ramp, the engine would just crank and never catch. I?d get it back out of the water and sometimes it would start, sometimes not. I?ve replaced the high pressure fuel pump twice and the low pressure pump once. My mechanic has replaced the relay twice, after which it seemed to start and run fine. But then when I took it out, after perfect operation for about 30 minutes, the engine quit suddenly while cruising at 3200rpm ? no cough, no rough running, no warning ? and wouldn?t restart. This has happened twice, each time after my mechanic has gotten it running again by replacing a relay. I?ve cleaned the fuel tank pickup tube, cleaned all debris from the tank, made sure the tank vents are clear and removed the check valve ballbering from the pickup tube on advice of my mechanic. the fuel filters were changed out less than 50 hours ago. I see no water in the fuel I drain from the filter.
When I turn on the ignition, I do not hear the electric primer pump that I usually hear before starting so am guessing another relay is blown.
any ideas at this point would be greatly appreciated.
