5.0 Mercruiser no start issue
gill248
Just got an 05 tracker boat with a 5.0l mercruiser engine. The engine will crank and want to start up but soon as the engine catches itself to fire it dies. It will run on starting fluid but soon as that runs out the engine dies. Not sure what carb is on there or what to check
Re: 5.0 Mercruiser no start issue
Ayuh,... Sounds like it ain't gettin' any gas...
gill248
it is getting gas from the pump to the carb but im not sure from there. I pulled it apart and there doesnt seem to be anything obvious that it wrong. On the mixture screw is there a baseline to set it at?
Ayuh,... A turn, turn, 'n 1/2...
But,...
Yer problems are Much deeper than that....
Don S
Use the throttle and give it some gas when starting, it's not EFI like your car.
It will run on starting fluid but .........
NEVER use that stuff on your engine again. Get it off the boat.
gill248
ok pulled the needle and cleaned it out and it started and ran for a couple seconds then died out. when i give it gas it dies instantly almost like there is a clog somewhere starving it for gas. I had someone start the engine while I looked down the carb and there was no gas being sprayed on to the back of the flaps. Is there a way to adjust the level of the gas inside the bowl? Or is this more of the mixture screw out of adjustment?
Ayuh,... It's called Rebuildin' the Carb... With a rebuild kit....
gill248
ok on a rebuild are they hard to do or just replace the parts that come in the kit?
Ayuh,... It takes a tank of solvent, 'n compressed air in yer shop to do it Right...
gill248
Anyone can fix it right the first time. It takes a real tech to do it a second time
