livethedream
- Jul 24, 2008
- 45
Hi folks, hate to introduce myself by asking for help, but it happens. i'm new to the boating world and if its as addicting as motorcycling i'll be around here quite a bit to yack and push buttons.
so i'm moderately mechanical and bought a fixer-upper 2000 chaparral sse200. i'm trying to get it running and need some help troubleshooting. here's some background... it wasn't well cared for and sat for an unknown, apparently long, amount of time. the fuel in the tank was nasty yellow and some bits of debris in it and the fuel filter was rusty... given it and the tank had about 15% water. i siphoned out the tank, changed the filter and cleared the lines out and put fresh fuel in, then cleaned all the (fouled) plugs.
with that it started and seemed to run quite good on the muffs, but the next day it was miss firing and stalled and now won't restart.
i pulled the plugs tonight and did a compression test. i don't know the technical number of each cylinder but looking to the stern and down at the motor, they were:
..........stern..........
1 - 150 ...... 5 - 150
2 - 150 ...... 6 - 120 *
3 - 150 ...... 7 - 150
4 - 150 ...... 8 - 150
120 PSI is ok, but does mean something is wrong at cyl #6, or no?
Also, all the plugs were darkened again since cleaning them the day before, except cyl #3 looked exactly as it did when i cleaned it. Like there's no fuel going to it. That plug does spark when grounded though.
Tips on what to do next, or what's happening in there?
