Re: 5.0 / 5.7 GI PEFS cutting out and popping at mid-range rpm
Well the TPS did not fix it. My MAP sensor, TPS and injectors were all purchased at local auto parts store and were cross referenced to fit VP but I believe they are all just aftermarket GM replacement parts. Would this matter or make a difference? I will check the injector pulse as soon as I get a chance. If the injectors are failing when the MAP vacuum is hooked up what will that tell me? I will probably be putting it in the shop next week.
