4hp Evinrude won't start
boat_4_fun
Just started working on a 1990 4hp 2 stroke Evinrude Yachtwin. No manual but I am going to purchase one.
I have spark.
I have fresh fuel coming out the fuel pump when cranked over.
How can I tell if I need to rebuild the carb?
This engine came with a sailboat and hasn't been cranked over in at least 5 years.
raczekp1
Re: 4hp Evinrude won't start
hi.
maybe just clean the carb,should be enough.slow speed needle,turn in all the way and 1.5 turn out
put new spark plugs
kbait
Will the spark jump 1/4" blue bolt w/tester? Just holding the plug to ground won't show the quality of the spark and may be poor. If you spray a bit of premix in the carb throat and it fires for a couple seconds, it's likely a fuel delivery issue..
JB
Go to the top of this forum, the Top Secret File, and do "Awakening a sleeping outboard" and, if needed, "Outboard won't start".
Let us know what you find. :)
raczekp1
i had 2 this type of motors.92 and 94 year.nice motors, and easy to start.
and low weight.
boat_4_fun
Thanks. I did get it running. Now in my trashcan I have lots of oil. I read awakening a sleeping outboard very helpful. I will follow the directions for the lower unit and see if we can't get the oil leak fixed.
SolingSailor
I also have a 4 hp and often run it in a trashcan. It's surprising how much oil (which is actually from the exhaust) ends up floating on the water's surface. But that is normal.
You should make sure that your lower unit is not leaking, but I would guess you're actually looking at exhausted unburnt oil, and nothing to worry about. When you change your lower unit oil, if the old oil is not milky looking, you're good to go.
raczekp1
its unbarned oil from your mix.
for sure its not gear case oil
kenmyfam
Very much doubt it's from the lower unit. as said it is most likely from the exhaust. However lower unit should be drained and re-filled anyway. Check condition of the oil when draining.
boat_4_fun
Thanks. I don't have water shooting out from anywhere either so I'm guessing I need a new pump. I have the manual on order and don't want to start taking things apart until I get that.
