4hp Chrysler
carleton
I am having a problem with this 4hp Chrysler model 42H79F.I have gas and a spark but it want hit a lick.Where should I look for where the problem could be?
Thank you
Jack
wickware
Re: 4hp Chrysler
Pull the plug and check for compression. With a gauge it should be close to 90-100 in 3-4 pulls IMO. Without a gauge you s/n be able to hold the compression in with your thumb or finger. It takes Spark/Fuel/Compression To Fire!!
carleton
Re: 4hp Chrysler
Compression is good.What am I missing?
carleton
IamCanadian
Re: 4hp Chrysler
is the spark strong and blue? is the timing set right?
Frank Acampora
Re: 4hp Chrysler
Assuming it is the two cylinder, water cooled 4: Are the plug wires on the correct cylinders? If they are switched, it will spark 180 degrees out of timing. It will not fire and will not even backfire. It will just sound like it is not getting either spark or fuel.
wickware
Re: 4hp Chrysler
What year model related to Mag or electronic ignition?
Have you changed the plug?
If Mag Sys, have you checked the point?s condition?
When did it last run with good performance?
Do you have the history of the past that led to this matter?
carleton
Re: 4hp Chrysler
I bought it and it would run very ruff. I put a new carb. and a new set of points on.Has not started since.
wickware
Re: 4hp Chrysler
Please post a pic of the new set on points you installed (up close but showing all the inside of the magneto system. Please post your steps and specs of setting the points. Such as: .030 at TDC which is only an example vs correct. No harm intended in this info vs trying to help you. Attached is my 1970 35 HP Chrysler Mag sys If You Have Not Seen It Before. LOL! I feel we'll have this Monster running soon.
