Practical Outdoorist
Thread starter- Joined
- Nov 4, 2018
- 12
I have a 1990 Johnson 48SPL. 90 PSI on each cylinder. Spark through both plugs. Yet only the top cylinder is running. If I pull bottom plug wire ... NO difference in idle. Put it back and pull the top ... motor shuts off. Unspent fuel in bottom cylinder. I swapped the carbs to see if the problem would follow. It did not. Getting milky oil from exhaust. BTW I have a Jet Pump on this Motor. Could this problem be exhaust related?? I appreciate any help I can get. Thanks.
