is it possible that the upper crankshaft seal could be bad and suck enough air to efect the idle
M muddmarlin Recruit Joined Jan 16, 2013 Messages 5 Jan 18, 2013 #1 is it possible that the upper crankshaft seal could be bad and suck enough air to efect the idle
Levinz11 Senior Chief Petty Officer Joined Apr 1, 2012 Messages 726 Jan 18, 2013 #2 Re: 48 spl is it possible I'm going to go with...yes. But read my sig after reading this.
Silvertip Supreme Mariner Joined Sep 22, 2003 Messages 28,771 Jan 18, 2013 #3 Re: 48 spl is it possible Since the crankcase goes through pressure vacuum cycles, of course it can affect idle.
M muddmarlin Recruit Joined Jan 16, 2013 Messages 5 Jan 18, 2013 #4 Re: 48 spl is it possible not showing any signs of leaking but when sprayed with carb cleaner under flywheel idle smooths out
B boobie Supreme Mariner Joined Nov 5, 2009 Messages 20,826 Jan 18, 2013 #5 Re: 48 spl is it possible You may want to stick to one post as it's less confusing !!
