48 evinrude
Eric 15
Will only idle at full throttle has new gas oil mix new condenser any suggestions on what to look for to fix
clemsonfor
I would put this question in the Jonny Rude engine forum for maximum exposure. How long has it been since carbs were rebuilt. Sounds like classic plugged up carbs. Low speed circuit partially clogged be my guess. But only a guess since we have no idea of the maintence and work history other than the gas is fresh. And these motors don't have condensors? I think the 48 was made in the 80s or early 90s only not an old school points and condenor era motor.
HotTommy
Yep. Fixing a motor depends more on what is written on the cover than on what kind of boat it is hanging on. See if a moderator will move this thread for you.
ahicks
Is the throttle cable hooked up at both ends? Carb linkage on the engine side?
F_R
Honorary Supreme Mariner
Are you telling us it is a 48 horsepower motor, or are you telling us it is a 1948 motor. There is a whale of difference in the question and answer
clemsonfor
Good point. I was assuming he was talking about a 48 Special motor. I guess I could be wrong but I was assuming most people wouldn't hang a 1948 motor off a pontoon???
