48 Evinrude SPL idle problem
Jpurvis
idled fine when first got it but had to pull start it. Took it to the shop and they put a new starter on it and rebuilt the carbs, etc. Now it wont idle over a few seconds cold or hot. It just lopes and dies. I have to choke it and give it gas for it to crank when cold. and I have to give it gas to crank when hot. It runs fine top end though. the bulb pumps up hard and stays hard.
Ralphy
Re: 48 Evinrude SPL idle problem
To save the xperts some time, you might want to give year and model # but sounds like gummed up carbs and/or fuel pump to me. If you pump the primer bulb does it help keep it alive?
Jpurvis
It is a 1993 but I don't know the model number. It has Power Tilt, Trim, I also forgot to mention that it has been this way for more than a year now, and it has not gotton worse or better. the bulb stays hard when it dies.
