470 tune up
e5earley
1980 Chaparral 187 with 470. Last season had trouble keeping it running. Never got it on the water, would run on muffs initially, then couldn't keep it running. Installed new points, coil, plug wires, and plugs. Rebuilt carb, coverted to alternator. Previous owner had converted to electric fuel pump.
Gave up on it last year, now back to working on it.
Starting with ignition system. Set point gag to .018. Coil ohms out within spec, strong spark on all 4 plugs. Engine started and ran. Runs rough, but expect that until I get dwell and timing fine tuned.
Now for my question. Checked voltage at purple wire at coil and I get 12v with key in run position. Disconnect wire from choke and coil to check resistance and it shows no resistance. Which explains the 12v at coil. Maybe someone has removed the ballast wire? The replacement coil I installed is an external ballast coil. Since I have 12v at coil should I install an internal ballast coil? Don't want to burn the points up and have the coil overheat. The coil that was on it was solid black with no markings, so no way to tell if it was internal or external ballast.
stonyloam
Do a compression check to make sure your head gasket is in good shape. A weak cylinder could be the reason it is running rough.
e5earley
Thanks for the response. I'll perform another compression check this evening. Did one a year ago and all was well. Still wondering if I'm getting 12v on the purple wire does that mean the resistance wire has been removed. Or does the voltage only drop when the points are closed? Probably over thinking this. But want to rule out any ignition issues before I go anywhere else with troubleshooting.
wrestling coach
The purple wire is the resistor wire. It should be a solid single strand wire. It runs from choke positive terminal to coil. It flows electricity after the engine starts and the key is in the run position.
e5earley
I was overly complicating things. You can't measure voltage after a resistor unless you have a complete circuit. No current so it will only show source voltage level, hence needing the points closed to get a measured voltage drop. I'm clear now. I'll set dwell and timing today and proceed from there. Thanks for the help.
