470 temp question
Blue t
What is the normal operating temperature for a 1988 165 hp 470? It runs around 190 on a 96deg day and the lake water is like a bathtub. I am about to do the raw water impeller but I would like to know where it is suppose to be.
Fordiesel69
Re: 470 temp question
Mine ran 164 on the coolant fill tank, and about 135 on the exhaust elbow. Also clean the heat exchanger each year. You can use a chemical flush only AFTER you disconnect it from the engine. No need to put chemicals into the leak prone cam seals!!!
