470 Outdrive
ddzhere
I have a complete upper and lower outdrive unit from a 79 mercruiser 470. Can anyone tell me what else besides a 470 this unit will fit? Thanks!
stonyloam
Re: 470 Outdrive
That should be a 1.84 ratio so would be OK for 4.3 l V 6's.
Bamaman1
Re: 470 Outdrive
The I/O unit you're talking about is the second generation for Mercruiser, and it's called a Mercruiser I.
The 470 outdrive is usually just put on a 470. Its gear ratio is somewhat unique, and they often use higher pitch props.
I wouldn't try to put such an old outdrive on another engine. It's doubtful it'd fit anyway.
wca_tim
Re: 470 Outdrive
Huh?
