Grant Ingle
Thread starter- Joined
- Aug 17, 2001
- 49
Having problems with this 470 Merc. Originally had simple overheating due to a leaking heat exchanger. Replaced with upgrade 4" unit along with impeller and T-stat. Ran at 180 degrees for several minutes on the lake then began overheating, finally turning to steam by the time it reached the dock. We have already blown HP air thru the water passages from the outdrive water tube to the hose coming off the regulator. Currently replacing the upper portion of the water pocket cover assy but quickly running out of ideas. Wondering if perhaps there is something common to explain this problem?<br /><br />Talk about a head full of steam!
