470 heat exchanger help please
I'm getting my boat ready for the year and somehow I misplaced the heat exchanger end gasket and bolt to hold it in. All I located was the end cap. Does anyone know the bolt diameter and length and also the outside diameter of the end cap gasket? Thanks a bunch I'm hoping to get her fired up tonight
gasket is same diameter as outside hx shell.
pull the other end cap, use the gasket as a template (or buy one - they are cheap). and you have your answer on the bolt
I'm about 20 miles from a hardware store and was hoping to get actual bolt measurements so I could stop on my way home from work, the gasket I'm not too concerned about because I can just make one
