4606 evinrude 4hp 1976
Orion3974
I am having a difficult time identifying where the water comes out of the motor. Can anyone tell me or show me with a pic? I really don't want to ruin this nice outboard as I was my late grandpas.
Thanks
Crosbyman
on my 71 it comes out 6-8 holes centered each side of leg just below mid point 3-4 holes each side to spit water out
F_R
Honorary Supreme Mariner
Whatever the exhaust just happens to blow out. The rest goes out with the underwater exhaust.
Vic.S
Thanks
It leaves underwater with the exhaust gases from the outlets at the joint between the gear case assembly and the "leg" or exhaust housing .
You should also see a few droplets, or a mist, blown out of the exhaust back pressure relief ports
there is no telltale on this motor
Orion3974
awesome! So I have some drops spitting out the holes on the leg. Touching the leg and it doesn't get overtly hot. This should be a good indication the the cooling system is cooling adequately right? Also the two dials for low and high speed. How should these be set when going slow and fast?
Crosbyman
I think whatever it spits out is a good sign but in reality you should service (replace) the impeller if it's origin is unknown
needles should be GENTLY seated in then...... turned out about 1.25 - 1.5 turns........ start and warn up the engine go full
speed and adjust the lower (HS) needles mid point between flooding( out to much) and starving (in to much)
then adjust the top needle the same way in idle mode . it is better to be a tad to rich than to lean
after making adjustments wait a few minutes for the adjustments to stabilize and visit Leroy's site for lots of info on these oldies
Vic.S
You should be able to touch and maintain brief finger contact with any part of the power head except around the spark plugs and the exhaust manifold cover.
If you cannot , or if a splash of water sizzles and boils or if the paint is discoloured or if it steams from the relief ports its over heating.
Always a good plan to replace the pump impeller if it not been done recently or if you dont know its age.
Full detailed instructions for adjusting the mixture needles can be found on the engine FAQs board http://forums.iboats.com/forum/engi...nts-for-asorted-carb-variations-by-joe-reeves
Also other topics that may be of interest on the same board
