45HP Chystler not starting
wpvaneyssen
Hi all,Changed impeller and gear oil on outboard,now motor does not even turn,only choke is activated when ignition turned!Checked Battery,okay!Please help...
JB
Re: 45HP Chystler not starting
Go to Engine FAQs Forum. Do "Outboard won't start".
eurolarva
So motor ran fine before changing impeller and oil. Did changing the impeller happen because the motor over heated? If you pull the spark plugs out can you easily turn the flywheel clockwise?
wpvaneyssen
Motor was not overheating;flywheel does turn...what do I check next?
pmat1
Do you hear the Solenoid for the starter click? if so, try manually spinning the starter gear up and see if the starter is frozen up. My rude does the same thing, until i whack the starter with a wrench. But not too hard;)
wpvaneyssen
Checked wiring...discovered starter mech block became misaligned so could`nt activate switch...once aligned,it started!thanks
