Captain Bravo
Thread starter- Joined
- Jul 2, 2011
- 49
Hey guys. I have a 45hp Chrysler 2 cylinder about 1978 vintage. It has had a fuel problem for a long time that I haven't been able to figure out. After priming, it will idle and run at low throttle settings very well. The first time to try for cruising speed, it will take off ok, but after running for about 5 to 15 seconds, it slows down like it is running out of gas. If I drop the throttle back to idle quickly enough, it will continue to run. Otherwise it will stall. I can prime it and it will start right back up. After doing this 3 or 4 times, it will eventually reach planing speed, but it will never run at full throttle.
I have rebuilt the carb, and replaced the diaphragm about 2 years ago, but neither really made much of a difference. I recently found this thread by googling.
http://forums.iboats.com/showthread.php?t=258384&page=1
It says that there are 3 check valves that should be replaced. I couldn't find any check valves in the iboats store. Do I just call NAPA and ask for check valves and gaskets for a boat motor? Should I replace the diaphragm again while I am in there?
Thanks.
Thanks.
