455 olds motor from car work in boat
sny97321
I have a 73 gastron carlson cv-19 jet boat. After taking the motor out for a rebuild I found a cylinder cracked real badly. my question is can I use a 455 oldsmobile engine from a car and just swap the heads and other parts to the new motor or do I have to find a marine engine thanks jim
projectcop
Re: 455 olds motor from car work in boat
Hello;
Well you have 2 choices here.
1. Yes; they are the same, but you should at least disassemble the motor and put it back together utilizing a marine gasket set.
2. Find your nearest machine shop and ask them if they can "sleeve" the cracked cylinder in your existing block. When done correctly, this type of repair is at least as strong as the original cylinder wall.
Walt T
I would not re-sleeve. The block is junk. The car 455 is fine and as the man says take it apart, check it out, re gasket it and install it. I love those old Carlsons. These jet boats are loads of fun to goose to 5000 rpms and a sleeved motor isnt made for that. Cheaper to use the car motor anyway.
Bob_VT
If you are going to use a salvage yard motor you are going to want the camshaft (or match the camshaft) from your current motor. Freeze plugs should be changed and all of the "marine" electrics and fuel pump should migrate to the new block.
The blocks are essentially the same just the marine parts are different.
MikDee
Banned
The 455 Olds motor, has the biggest bore as opposed to the smallest stroke of all the GM engines, it likes to rev freely. That's why it is suited best for a jet boat.
Lone Duck
Master Chief Petty Officer
the 455 olds motor, has the biggest bore as opposed to the smallest stroke of all the gm engines, it likes to rev freely. That's why it is suited best for a jet boat.
yup!!
sny97321
thank you. as luck would have it I found someone who has a buick 455 motor that has been machined with all the parts there but it needs to be assembled and I need to get the bearings and the gaskets for it. Do i need to use the old heads because of how the risers bolt on. what is the difference between a marine gasket set and a standard set. thanks again for the replies
MikDee
Banned
The Buick engines have the longest stroke of all the GM motors, basicly a torque, not an RPM motor. Pontiac, & Chevrolet, rank between the Olds, & Buick, stroke wise. Good luck trying to find marine parts for a Buick engine.
harleyman1975
Ensign
Yea the buick is not the same as the olds motor...don't do it!
