454 with Milky oil found on pre-purchse
beech2000
Looking at an older boat with twin 454's. I see slightly milky looking oil noted on starboard engine dip stip. Possible causes?
Manifolds, Cracked block, head gasket? Compression check shows all cylinders between 130-140.
I think winter moisture from sitting but have doubts as port engine has normal looking oil.
beech2000
Looking at purchase of an older carb powered twin inboard cruiser with 454's. I noticed the starboard engine has slight milky appearance on dip stick. whats up? cracked block, heads, manifolds??? all of the above?
chartersj
Get them to change the oil and take it for a spin. Just running on the hose sometimes isn't enough to tell
alldodge
Have trouble thinking of condensation, think more a leak from intake gasket since compression are ok. Was the motor brought up to full running temp and then compression done?
In any case water in the oil, I would think the need to rebuild unless its proven where the water is coming from
tpenfield
I vote for a cracked block or bad exhaust manifold gasket. You should proceed with caution. 454 engine blocks are a bit pricey.
harringtondav
Agree with a leak or crack somewhere. My boat sleeps in IA winters, with an oil change before slumber. I've never seen condensation discolor the engine oil.
doubt its condensation.
most likely cracked block from improper winterization or bad manifold to riser gasket.
FYI, a rebuild on a BBC will be about $2500
QBhoy
Only time I’ve seen condensation showing milky oil is on the inside of the oil filler cap and perhaps at worst a wee bit showing on the rocker gear when looking in. Never really known it to show on the dipstick. That would suggest something else, I’d think.
