454 Mercruiser starting "on stand" help
judgebobo
I just finished rebuilding my 88 454 mercruiser. I have searched other threads and just cant figure out the exact way to get this engine stared without a remoted ignition. What I have done is bat POS to S on starter selonoid. bat NEG ground to block. Bat POS to Coil POS then running hot wire from battery positive to starter not sure if this is right set up, not working and actually pretty scary. I would love some feedback. This has been a long rebuild and I am ready to put back in boat. Thanks for any assistance.
Bobby
*Edited to say No it is not on stand I have it on blocks and very sturdy. It wont run away on me. I also have hose ready and fuel ready to go.
dubs283
Re: 454 Mercruiser starting "on stand" help
you should have some chains from a hoist or other overhead support attched to the lifting rings with some tension to aid in supporting the engine, i would not recommend running it just sitting on blocks
that said, you need to jumper the primary side of the slave solenoid to to get the starter to turn over, not to mention you will need a fuel and cooling water supply to run the engine
Pete104
2 cables, 1 to the starter. The other to ground. Red = starter. Black + ground.
2 jumpers, 1 12volts to positive side of coil. The other jumper; connect 1 end to 12 volts. The empty end of second jumper, touch it to the small yellow/red wire at slave solenoid.
judgebobo
ok thanks gentlemen. Very good advice dubs, I keep it attached to the hoist just for extra security. I am going to try now.
judgebobo
okay i have hooked up as said and I am only getting clicking noise. One clack per touch to selonoid. please advice. could this be battery not charged enough?
judgebobo
Pete thanks big time I had no idea i had to use the slave solenoid. okay i have hooked up as said and I am only getting clicking noise. One clack per touch to selonoid. please advice. could this be battery not charged enough? If you have anymore inf can you reply back to the thread.
Bobby
Pete104
Well yeah, you need to have a hot battery!
judgebobo
Yes, like to get it started and ensure I dont have any other issues before putting back in the boat. My battery is also fully charged and I am getting a clicking noise when I engage the selonoid. any suggestions?? Maybe not lined up good with flywheel??
judgebobo
Thanks alot this looks exactly like what I need. After reading through this, I see I will need to turn igition a few times throughout the test. Does anyone know of a way to do this test thouroughly with engine out of the boat?? Please advise. Bobby
dubs283
keep in mind all the key switch is doing is providing 12 volts to the primary post on the slave solenoid (yel/red)
all you need to do to turn the starter over with the engine out of the boat is provide 12 volts to the primary post on the slave solenoid (yel/red) - you should just be follwing the engine side of the troubleshooting guide as the boat wiring has been taken out of the system
seeing as how you are getting a click from the slave solenoid it sounds as if you are jumpering it correctly, your issue is in the wiring OR you have a faulty component
joncrisler
I thought you had to have power to both the solinoid AND the starter motor. The starter motor is going to take big-amps. I dont know for sure on this...comments ?
Pete104
The heavy cable from positive side of the battery goes directly to the starter. It will connect the rest of the system from there. Provided wiring hasn't been screwed up.
That heavy cable could/should be "red" or black with some kind of indication that it is in fact positive.
Take it away Dubs!!!
judgebobo
ok I may be making ground I had the starter tested and it is good It appears to be engaging the flywheel and moving it ahair or towo but that i it. Does that help anyone out there with any ideas.
Pete104
Did you even look at the link Dubs Posted?
judgebobo
I apologize, Yes I looked at the link and did the testing. I did not come up with a problem. I even took the starter off and took it and got it tested. Just engaging the starter only to make sure it is in fact engaging with the flywheel is when i noticed that it engages but does not turn the fly wheel. took the plugs out so there is no compression and it engages the flywheel adn it turns about a hair and that is it. Any ideas?
dubs283
can you turn the engine over by hand with the plugs out??
judgebobo
putting a socket and wratchet on the front damper nut turns the engine over with little to some resistance
*** with plugs out
Pete104
Can you hear where the "clicking" is coming from?
