S.A. Baker
Thread starter- Joined
- Aug 9, 2015
- 227
Winterizing time. Drained gear oil,, didn't seem like much came out.... but had just a trace of water...may have just been condensation there was so little. The question is....all the gears are in the stump stabber part of the very lower end. Your supposed to pump oil into the drain until it comes out the vent. The vent is 11" up from the drain,not far under the water pump. Why do you need gear oil up that high? What needs gear oil that far above the actual gear case itself?
