oldboat1
- Apr 3, 2002
- 9,612
Yup. always easy enough to check the temp on the top of the head to make sure it runs at proper temp. Look for a good flow of water out of the port on the rear of the leg within seconds of start up (actually, during cranking if it’s a little slow to fire up).
Pumps are pretty simple, as mentioned. I like to at least turn the shaft by hand after the impeller is installed (can hear and feel the impeller turning in the housing). Different strokes….
Hope you post back after test running.
