I am looking at purchasing a boat with a 1996 40hp Mercury outboard. Did a compression test and got 110, 115, 116, and 119 on each cylinder. Is this about right, or should I be concerned? Also, the water come out was extremly hot, steaming a little. We ran it with a small cheap pair of ear muffs-could it be not getting enough water to cool? If I put boat in water and run, should water coming out be warm or cool? Im sure not steaming! Also trim motor needs replaced-easy fix? approx cost? Anything else I should look for? Thanks,
