40 hp mariner dropping cylinder
DK_BOE_SR
Hi all
40hp Mariner drops cylinder when run about .5 hr. or so. Has been sitting for about 3 yrs. while working in another state. new fuel tank, new fuel hose, new water pump. Motor runs fine on hose and in water until it drops cylinder. Once run for a while, will not come back on throttle. It just seems and sounds like it is bogging. fuel bubble is hard and no difference when pumped. can idle for a while and when throttled up sometimes will catch after stuttering a while. Can the coil be heating up and failing on one cylinder? Engine has one coil and fires both plugs at once. 40 hp mariner, 40E 676BS105101. Any ideas appreciated.
Dave
gm280
dk_boe_sr :welcome: to iboats. Nice having you aboard...
When your engine drops a cylinder, do you actually know which one is dropped? If so, swap the spark plug wires and see if the dropped cylinder changes positions. If so, buy a new coil, if not, the ignition isn't the problem... JMHO!
