40 hp johnson loose hose
aloha boy
Hi All: Got this johnson 40 hp,2001 model J40VLS1B. While putting back the lower cowling noticed a small hose under the carb, loose. One end looks to be connected to the intake manifold under the carbs. the other end about 5" long is missing the clamp and just hanging. I tried looking to see where it should be connected to but could not find the spot. Any suggestions would be greatly appreciated. Thanks
flyingscott
Look for a nipple on the bottom of the air box sounds like the reclaim line
aloha boy
Thanks flyingscott, its night here so I will look at it in the morning. Don't know where I can get a small clamp for the hose, I'll look it up or use a plastic strap.What does the reclaim line do?
flyingscott
It takes the fuel that accumulates in the air box and cycles it back thru the motor. You should not need clamps for it just put it on.
