I bought a 40 hp force by merc last year cleaned carb and started right up!
I have used it several times since then. a couple of weeks ago i went to start it and it took a couple of tries to get it started but it did. Mind you it would always start on the first crank. I went to start it last weekend and it took about 6 cranks to finally start. I brought it home, put a spark tester in it and the light wast very dim. I also took the sparkplug out and grounded it and seamed to be weak. I also cleaned the carb and replaced the fuel line just cause. If i put a volt meter on the SP wire and cranked it what should the voltage be?
Should I try testing anything else? I don't want to mess anything up, i like this motor.
