40 HP Force to 50 HP ?
picker
According to the repair and parts manuals, my 1998 40 hp force is identical to the same year 50 hp motor except for the high speed jet in the carb. Thinking I could get 10 extra hp , I changed the jet. I learned that aparrently it's not that simple. The motor ran real rich and would not go over 3000 rpm. I think it needs more air. Anyone out there know what the difference is ? Maybe something in the reed valve system ? How about the exhaust system ?
clanton
Re: 40 HP Force to 50 HP ?
Port timimg in block and exhaust tuner, maby more. Check part numbers on block,carbuator, and exhaust tuner.
12Footer
Where is HP rated at? Prop or powerhead?<br />Could be the only difference.<br />I'll bet if Boyessen makes them,a set of composite reedz will perk her up :)
