Backpackerii
Thread starter- Joined
- Aug 21, 2008
- 2
I am new to boating and I purchased a 16ft grumman with a 1992 40 hp Force engine. I have had it out 4 times and each time I had to be towed back in for different reasons
. The last time the pin that holds the upper and lower shift rod had fallen off. It would only go in reverse and neutral. I took it in and had it turned up, replaced the water pump, rebuilt the fuel pump (found a hold in the fuel pump membrane), new fuel filter, new plugs, etc. Put it in the water and had a hard time starting it but was successful. As I cruised every once in awhile the motor would jerk, the faster I went the harder it would jerk
. It seemed like it was going from forward to neutral than back into forward, no problem in reverse. I took it back to the mechanic, he said the lu was shot, I took to another mechanic and they said it was shot. In reading the forum I am wondering if anyone else had this problem and if you can give me any recommendations? Thank you in advance.
