40 HP Evinrude slow to pick up speed.
Curwin
Hey my 40 HP evinrude that I just bought goes pretty fast once it gets going, but from a dead stop to start its very 'boggey' and is slow to get into high rpm's. any advice?
jwilkey84
Re: 40 HP Evinrude slow to pick up speed.
hmmm...I am by no means an expert but I have a 40 that was that way and it had low compression so I no longer use it. The compression was like in the low to mid 90's
HighTrim
Any new motor to you should have the carbs rebuilt and bathed. I would start with this, paying special attention to those jets. Although not specifically for your problem, do a decarb, change the lower unit oil, impeller and spark plugs and let us know what you find. This may help for the carb rebuild
"http://www.meegsonline.com/tmd/TMDsVideoChronicle2.wmv"
Evinrude Boater
Welcome to iboats Curwin. To offer proper advice we need to know what year motor you have and the history of the motor. A 40 hp motor on a 14' boat should pull a skier out of the water. In fact, old brochures show two people skiing behind old 40 hp Larks.
jwilkey84
it's not popular, but last week I skiied behind my 14' fishing boat with a 40hp mariner tiller!
tashasdaddy
compression check, the boat it's on what size, and material. model # of motor. i learned to ski behind a 14 ' wooden boat, with a 1950 15 hp rude. i now have a 14' 1956 Duracraft aluminum runabout, 93 40 hp, will run out at 30 MPH. took a while the get the engine height and prop right.
