oregonducker
- Feb 10, 2004
- 189
MFS4A2D 2005
Starts easy and runs fine at high idle and up but won't idle down and stay there.
I've had it several years and the carb always hates sitting around not being used whether I drain it or not it wants to be cleaned. Anyway, a week ago I went to run it at home and it wouldn't idle so I pulled the carb, took it apart, soaked it/cleaned it the way I always do and put it back on but got the same problem. So I took it off and made extra sure it was clean. I could see carb cleaner spray coming out of all the little holes and through all the passages. I'm pretty sure it's clean. Still wouldn't idle. I then ordered new gaskets for the insulater/spacer thinking one of them was letting air by. Just put those on today and it still won't idle.
How many turns should the pilot screw be at to start with?
I have the throttle stop screw set to where it just comes off high idle which, if I'm right, is where the pilot screw takes over. I've adjusted that from 1/2 turn out to over three turns out but it does the same thing no matter where the pilot screw is and now I don't remember where it's supposed to be to start with.
Is there supposed to be an o-ring on either the pilot screw or the pilot jet? Someone referenced one on an older post but I don't see any listed in the parts.
