4 HP Mercury 2 Stroke, 1992, Carburetor Issue.
Greg_E
i just picked up a Mercury 4HP 2 stroke.
I read the sticky to identify the engine using the serial number. Using one of the links in that thread, I identified it as being a 1992. SN A907213.
The engine is in very good condition for its year, but when I tried to prime it, gas was dripping from the carburetor at the base gasket. I notice that one of the nuts that secures the carburetors was missing, so assume someone has made an unsuccessful attempt to fix it.
I do have the manual for the engine.
I did not find any aftermarket carb rebuild kits for this motor. Does anyone make one or is it a dealer only item?
Are there any common problems with theses carbs that I should look at first?
Also, I noticed that the recommended spark plug is not what was in the engine. The recommended plug is a NGK BP7HS-10 or BPRHS7-10. It had a Champion Y78C plug which is center fire plug ( not sure that's the correct term). In any case it is a fixed gap plug. Is that an alternate for the factory recommended plug?
Thanks for your replies.
Bosunsmate
Re: 4 HP Mercury 2 Stroke, 1992, Carburetor Issue.
try searching for this part # and see if it fits with your model
855546A 1
Is that the 2cyl or 1cyl?
Greg_E
Thanks for the reply.
I have since discovered that the engine is not a 1992. The site I initially used to identify the year incorrectly identified it as a 1992.
I think now that it is a 1986. I still have been unable to positively identify that serial number as a 1986, just that the serial number is higher than the beginning serial number for 1986 motors. When I search my serial number, it comes back serial number not found.
The carburetor is stamped WMD 7/85. I assume WMD stands for Walbro Marine division and 7/85 was the date of manufacture. They also used Tillitson carbs on that year. From the diagrams, they look very similar.
It is a one cylinder motor.
Greg_E
Thanks carholme. This is the first Mercury I've worked on so I'm still finding my way around. Have always worked on J/E motors prior to this one.
The carb has gas pouring out when I prime the bulb, but it fired up briefly on the second pull. I think once the carb is squared away, it will be a nice running engine. Someone was in the carb before me and didn't put it back together correctly.
