4 Blade SS Props: Solas Rubex vs Solas HR Titan
kallake
Can someone tell me the differences between the two props above and do they give reasonable hole shot and performance?
Considering one of the above for my 18' open bow 4.3 alpha 1.
3dees
Re: 4 Blade SS Props: Solas Rubex vs Solas HR Titan
the Rubex uses a flow torq hub. the Titan is a solid hub. hole shot is going to depend on the pitch and your setup. 4 blades usually will give you better holeshots, but may cost you a little top end.
kallake
Yah I realize that hole shot is dependent on pitch. I pretty well know the size and pitch required. It's just that some prop makes are duds and not worth the money and wondering if these are a high quality prop.
