4 blade ss prop for 225hp on 26' striper
dasjlm
I'm considering upgrading to a 4 blade ss prop for my 1998 striper with a 2000 225hp envridue fitch ram.
Recommended RPM: 5000 - 6000
# of Splines: 15
Gear Ratio: First: 1.86
I'd like to get on plane a bit faster and have reasonable fuel economy at mid speed. I'm not concerned about top end speed.
The boat is pretty heavy so I'm thinking a 4 blade ss prop 15" diam and 15 pitch might be reasonable.
Anybody have any comments/suggestions?
Thanks in advance
John
junior1113
Re: 4 blade ss prop for 225hp on 26' striper
what size prop are you running now and what is your wot rpm and speed? then we can tell you what you need. i run my 200 evin. at 5700-5800 on the boat you see with a 4 blade ultima turbo 4 17p witch is awsome. id run that motor closer to 6000 than 5000 especialy with that big of a boat. 2 strokes live on rpms. dont give them enough they die early. besides that 225 horsepower is rated at 6000. at 5000 youd have like 180 horsepower.
hwsiii
John, I am showing a 15" Pitch 4 blade SS will be perfect for your boat and motor combination. I show an all up weight with everything on your boat at about 6,400 pounds and the gear ratio for your motor at 1.86:1. With the Rev 4 running at almost top RPM you should expect about 40 MPH.
Boat and Motor
Prop Picker
H
junior1113
i suggest a 4 blade 14 1/4 x15 turbo ultima which has stern lifting characteristics they are awsome. less of the boat in the water is always a good thing. these props are second to none when it comes to dealing with rough waters
