tahoejag
Thread starter- Joined
- Jul 4, 2009
- 229
Currently running Mich Wheel 14 1/4 x 21p 3 blade alum. At WOT 48-4900 rpm on gauge, 43 mph (gps). moderately loaded (aprx 700lbs). SX smart tabs installed 60 lb. Recommended max rpm for 4.3l 190 hp is4400 to 4800. By reading these #'s sounds about the ideal set-up..however I am getting aprx 18% prop slip.
I have read thru other posts/threads that I may not even have the hp to go to a 4 blade prop in which I am looking to do.
As everyone recommends....drop 1 to 2" pitch when doing this. I feel that would give me better mid-range cruising and a bit more bite out of hole and LESS prop slip? 14 x 20p 4 blade alum - would it be a noticeable diff or should I drop to a 14 x 19p? I am losing 1/2 dia but gaining one blade. Would such a pitch change put my rpm's in the red? The props in mind are the merc alpha 4; quicksilver black diamond 4 or heard alot about hustler turning point legacy.....what's everyone's opinion....and/or prop suggestions. Thanks!
20.5 ft runabout
4.3l carb 190 hp
alpha I gen II 1:81 ratio
20.5 ft runabout
4.3l carb 190 hp
