4.3MPI Risers
Superjetjim
Looking at a 2005 Regal with a 4.3MPI, the broker doesn’t know when the risers were last changed. Looking at the picture (and EPA sticker) are these likely originals from 2005?
Also they look a bit questionable at the rear side?
itsathepete
Definitely looks like they need new gaskets as they have been leaking. Any leaks that you could see? Freshwater or salt
Superjetjim
Its been on fresh water for the last few few years (river, 5mph speed limit) and buying through a broker limits your ability to speak to the owner. Can’t even open the boat up to test at full power due to speed limit on the river.
Jmunk
To give you an idea as to cost, I recently put new Barr brand manifolds and elbows on my 4.3 (dry joint style, which appears your are as well). The cost was around $1100 for parts.
Superjetjim
Yeah makes sense, I’d prefer to be able to run it hard for 20min to make sure all is good. There is zero warranty through a broker in the UK, big risk really. It’s not cheap either.
