4.3L OMC thermostat removal and replacement help.
Status
Not open for further replies.
houstonnoob
How do you remove or replace the thermostat for 4.3L OMC? Please see the picture below.
Reinell-BRXL-191
Re: 4.3L OMC thermostat removal and replacement help.
It's just stuck.. use a little persuasion in the form of a screw driver to get it out... it has an o-ring that is between it and the housing...
houstonnoob
Does the thermostat itself suppose to be up there? I would assume it would be on the intake manifold and this to cover the thermostat like automobile does, wrong assumption? So it is replaceable thermostat and not replace the entire "thermostat housing"? How does that thermostat stuck up there and not lay on top of the manifold? Thank you for your input.
Reinell-BRXL-191
that's where it is supposed to be, you have to understand how the system works... it really is 2 systems.. Most people think the system works like a car, where cold water is passed in to the top of the engine from a radiator.. in the case of a raw water cooling system, the t-stat is actually keeping the water in the engine, until it is hot enough to be pushed out in to the exhaust cooling system.
If the engine is cold, the thermostat assembly routes the water to the exhaust risers where it is passed overboard through the exhaust. The water contained in the engine remains in essentially a closed circuit moving from the engine cooling passages to the thermostat assembly to the engine circulating pump then back to the engine cooling passages. This closed circulation allows for a quick warmup.
As the temperature of the water passing through the thermostat assembly increases, the thermostat begins to open allowing the hot water to be sent to the exhaust manifolds where it is discharged overboard. The thermostat assembly also allows the incoming cold water to mix with the hot engine discharge water, this cooler water is now routed to the engine circulating pump then to the engines cooling passages.
This system uses the thermostat to maintain the engine within operating parameters. As the water temperature fluctuates the amount of cold water added to the engines circulating system is controlled by adjusting the discharge path of the water. If the engine is too hot, water is allowed to discharge via the exhaust manifolds and more cold water is introduced into the engines circulating system. If the temperature is too cold, the cold water bypasses the engines circulating system and is discharged overboard through the exhaust risers
bruceb58
Honorary Supreme Mariner
houstonnoob
Reinell & bruceb58,
Thank you so much for taking your time to explain.
nutnboltguy
this is the strangest thing ive ever seen. i was looking at mine this morning thinking the same thing... im new to owning a boat so i guess this is how it is?
Status
