4.3GS PWTR Raw Water Flow Question
Leedanger
99' 4.3GS PWTR
On the muffs with the water turned up to higher pressure than I'd normally run it at and outdrive in the down position I see no to little water coming to the inlet side of the raw water pump which I have disconnected from the pump itself. So somewhere between the inlet of the pump, heat exchanger, and the outdrive I have an issue it seems. Any thoughts specifically? I was hoping to not have to pull the drive but it looks as though I may have to.
Don S
Re: 4.3GS PWTR Raw Water Flow Question
The pump creates the suction that pulls the water up from the drive, not the pressure from the hose feeding the pump.
Leedanger
I knew that had to be air tight to work properly throughout the system, but I guess I expected the hose pressure to be enough to push it to that point...no..? I suppose the thing to do is just get some clear tubing as suggested and test it properly as I should have from the start. I just rebuilt this engine and after running it, for a short amount of time, there wasn't a drop coming out of the block drain cocks so I got nervous.
Does it matter which port of the raw water pump I put the inlet hose from the exchanger on? I have it on the bottom and the hose going up to the therm on the top....I am second guessing myself all over the place.
Leedanger
Don you just answered my question in another thread that I have this backwards....looks like I need a new impeller.
