4.3 with vortec heads
SHELBY3
just got my engine back together , install vortec heads and new intake , will there be any issues with carb as far as running lean ? its a 95 vintage with thunderbolt ignition, also how to time whens theres only one line on dampener ? thanks tim
Re: 4.3 with vortec heads
Ayuh,.... What Carb,..?? It'll be Close,+ Should only need abit of Tuning...
You're not really moving More air,... Just More Efficiently...
There's usually only 1 mark on the Crank pulley...
There should be a timing Scale on the timing cover...
180shabah
There will probably be some minor retuning, but the vac gauge and plug reading will tell all.
What carb is being used?
SHELBY3
looks like a carter / edelbrock, ? nos 9600s, 8005:confused:
slasmith1
weren't all the vortec's injected?
Ayuh,...
That Sounds like the Merc./ Weber carb....
It's a carbon copy of the Edlebrock performer,+ the parts,+ pieces are a direct interchange....
A Street/ Strip kit for the Eldebrock will give you Great Tune-ability....
