jglad
Thread starter- Joined
- May 15, 2007
- 32
Hi all,
I just got an old boat project running and now need to figure out what my best prop options are. I have a 93 Regal 17' bowrider with a 4.3LX alpha one set up. Got it running good and usually run it with half a tank (10 gal) of gas and 2 people in it, with the 23P black max prop that was on it when I got it, WOT is around 4500 RPM and top speed is right about 50 (GPS) on a smooth surface. It is sluggish out of the hole and when on plane the bow likes to bounce when I try to trim it up, unless I have someone up front.
I found a used Ballistic 21P SS prop that is much better out of the hole, I can trim it up and it runs WOT at 4800 RPM and top speed is about 46, that is OK, but I am a little worried about the high RPM's and wondered if there are some better options available.
Thanks for any help!
