vernonbluewater
Thread starter- Joined
- Jun 16, 2010
- 13
Starts right back up again, usually have to pump throttle to get it going, runs for 30-40 seconds then stalls again, repeat. I have been trying to figure this out for a while. Started by replacing oil pressure safety switch(mounts on oil pressure sending unit & cuts power to fuel pump if pressure drops below 4 psi). Getting voltage @ fuel pump on crank.(note- fuel pump gets voltage from battery on cranking but once running gets power from alternator) no luck. Pulled fuel tank supply tube, strainer @ bottom clean, replaced fuel filter, no luck. Replaced fuel pump, no luck.Checked carb on throttle pump, fuel squirting in - still no luck. Tried running off separate fuel tank in case of vapour lock or other issue with boat fuel tank - no luck. Bypassed oil pressure safety switch ( jumped wires together) - heard fuel pump turn on when turned on ignition - engine runs fine. Hooked safety switch back up - engine runs fine.Unhooked safety-engine starts to die-reconnect safety-engine comes back to life. Best I can figure is there was a bad connection. Tested boat in water for 4 hours yesterday-so I believe problem solved . Hope this helps someone with similar problem.
