4.3 Mercruiser with only 3 water drain holes.
jayhuf
Ok, so I have a weird question. Has anyone else seen a 4.3 mercrusier with only 3 drain holes. I have 1 on each manifold hose (blue plastic) and one on the starboard block (brass). I can't find anything on the interwebs. I looked everywhere for the 4th plug using a mirror and flashlight. Manual says 4 plugs but only shows picture of port plugs.
alldodge
There is one on the port side
and should also be brass
And if its 1996 and newer, there is one on the intake manifold T-stat cross over
Chris1956
V engine blocks almost always have a drain on each bank of cylinders. Your 4.3V6 should have a drain under each exhaust manifold.
