4.3 Mercruiser LX bogging down
hann2723
I just joined here and have been reading the posts to see if the bogging down problwm i have is normal. Well, apparently it is pretty common. I replaced the fuel filter, blamed the gas station, and after reading here, realized its probably my coil or ignition module. Once the motor gets warm, it bogs down under load and wont go past 2500-3000 rpm. After it begins, it will fire up again with no problem, but then progressively get worse, to the point of idling rough, then shutting down. I just bought the boat 2 days ago and it started the issue night before last after about a 10 mile ride. Its a 94 chaparral 1930 sst, and its at the shop now. I just want to make sure the symptoms match the diagnosis, so I can relay the info to the mechanics if needed. Thanks for all of your input
hann2723
Just got a call from the mechanic, he said it was a wiring issue at the fuel pump that was causing the issue. Still curious as to how the issue just began all of a sudden. Make sense to anyone else?
hann2723
Well the boat runs great!! Hope this info can help some of you down the road if needed.
