4.3 mercruiser engine installation trouble
markhaider
I recently overhauled my 4.3 mercruiser. and I am having a difficult time pushing the motor and driveshaft together. The motor mount adjustment is unchanged . I tried a good amount of force and turning the crankshaft. Any helpful hints out there would be greatly appreciated. Thanks Mark at holyonesfavor@yahoo.com
dutch135
Re: 4.3 mercruiser engine installation trouble
I'll take a stab, and ask if you are talking about
installing the outdrive? (guessing the motor
is back in the boat)
If so, did you get an alignment tool and adjust
your motor mounts so the alignment of the drive
shaft to the engine coupler is perfect?
tommays
Generaly you install the motor and then check the alignment with the tool and then install the drive last
It does not sound like thats what your doing ?
Tommays
markhaider
Do I need to pull the stern drive out, inorder to just install the motor??? any short cuts?? motormount height was not changed.
The Drive is the 1st thing to Come Off,+ the Last thing to Go On...........
There Ain't No Short-Cuts...............
The Rear Motor Mounts are built to be "Set Down On",........ Not "Slid Into"..............
