Cheesburger
- May 29, 2009
- 6
1988 Searay Seville 21CC 4.3liter.
I was given this boat, by a friend. It had been sitting for about 4 years. I was told the engine had been rebuilt twice already. I have changed the impeller in the outdrive and the waterpump that is bolted to the front of the block. I have also changed the thermostat. It ran fine while on the muffs. Temp came up and then went down and stays in range. After several test on the muffs, I put it in the water for a test run. It quickly ran up to about 190-200 and would not come down. I was reading a post that said to check the intake gaskets...I did and that was not the problem. I am very close to just replacing the engine altogether.
Help
Help
