Lou Bischoff
Thread starter- Joined
- May 4, 2012
- 6
I have a 2000 4.3 liter Mercruiser I/O. I noticed water intrusion in the crank oil upon an oil change. Changed the oil 2 more times, but still have a tan milkshake. The engine runs beautifully. Starts right up, no knocking or idling issues. I winterize by draining 5 blue stopcocks, probing the block openings with a wire, and filling the water pump hose with pink antifreeze. Cylinders are fogged with oil. There is no water on the spark plugs upon their removal. A water pressure test reveals a slight hissing in the oil filler spout at 30 PSI. Compression test (cold) reveals all cylinders but #3 at 165-175 PSI. Cylinder #3 is at 95, and rises to 105 after squirting oil in that cylinder. Any chance my issue could be a head gasket or intake manifold issue, and not a cracked block?
