4.3 liter chevy parts
alpapale
- I have an Volvo-Penta 4.3 liter (2001, 2BL 190 H.P)) which I understand is basically a Chevy Vortec 4.3 long block that Volvo buys, and put on their own exhaust manifolds, etc. Can I use an regular automotive oil filter on this motor ? If so, does anybody know a good parts number for the filter (AC-Delco , Purolator, etc.)?<br /><br />- What about spark plugs ? I'm inclined to use OEM's here, but I figured I get some opinions.<br /><br />Thanks Again!
12Footer
Re: 4.3 liter chevy parts
That is correct.The block is basicly the same.<br />I would stick with the O.E.M. plugs too,as operating temps and engine loads are totally different. The filters are all directly interchangeable on the mercruisers, so I don't think you'll have a problem using auto filters on the Volvo.<br />Thermostats are different, as they have to open at a cooler temp.<br />Alternators are the same internally,but in some marine applications, they put them in a different case, or use special insulated bolts or bushings (the old "dissimular metals" problem).
