4.3 L Spark knock *** Help please...
Happy Days
I had my old 4.3L Mercruiser replaced with a new block with a 4 bbl carb and roller cam. I have TB IV ignition with the control module mounted on the distributor. The engine runs great and has lots of power. The problem is a light spark knock that occurs in the mid power range. I know it's not my imagination because my wife can hear it too. <br /><br />Retarding the timing makes no difference except it runs worse. If I advance the timing, the spark knock gets severe at WOT. I'm running 87 octane now.<br /><br />Is it possible I should be running higher octane fuel or maybe my problem is in carburation??<br /><br />Any advice would be appreciated.
Haut Medoc
Re: 4.3 L Spark knock *** Help please...
Higher octane can't hurt......J
LubeDude
Good chance that your problem is in the prop, what are your RPMs at WOT? Posibly luggung the engine.
robfogle
I thought I read somewhere that the 4.3L needed 89 octane or higher.
If the Carb. is going Lean at the transion, or in the 2ndary circuit,..<br /><br />It can also cause Dentonation........
bluewater19
If you replaced that old motor with one that says vortec on the valve covers there is your problem.<br />The vortec motors have higher compression and require 89 octane minimum. The vortec motors were designed for fuel injection and will live off the knock sensors in a car with low octane fuel, but your TB-IV ignition doesnt retard timing when detonation happens. Try using the good stuff.<br />I had this same problem when I switched my 1992 over to vortec heads. If this doesn't help listen to bondo, He is the man when it comes to the 4.3 chevy!
Happy Days
Thanks guys.. My WOT RPM is 4600... and no detonation. The pinging occurs between 1400 and 3000 rpm. Below or above those speeds, all is well. I'm thinking I may have a vacuum leak but it runs real good. just a little pinging. <br /><br />I wonder if I need cooler plugs.. What do you think guys?
